How do i Get the codes on a 1991 deville?
Old Feb 16, 2014 | 11:56 AM
Juggastoned's Avatar
Default How do i Get the codes on a 1991 deville?
I bought an obd1 scanner but that didn't work as instructed, and i can't find a definitive answer after a googling. It's a 1991 sedan deville gold key. This is my first cadillac and it's got a bunch off little problems. I know i can't get help without the codes!!! Help!!!
Old Feb 16, 2014 | 05:35 PM
SimpsonTruckDriver's Avatar
Very easy! Turn your key to run (engine not running). Press and hold the OFF and Warmer buttons on your A/C Heater Control. All the segments will light up. Look over at your FDC (Fuel Data Center). Codes will be ran starting with E, then EE, then F, then FF and ending with .7.0. The E codes are engine codes (current and history) and the F codes are body.
TS
Old Feb 17, 2014 | 07:18 PM
You need to get factory service manual - Helm inc or search net .... many times are on ebay. Diagnosis is based on using the OBD built into car not a scanner. EE & FF current codes. E & F are history or intermittent codes. Lots of info in FAQ section
scard
May 15, 2013 09:29 AM
Prevch
Dec 22, 2011 07:23 AM
dfb52764
Aluminum Block V8s
Jan 11, 2009 09:50 PM
canicam
Dec 16, 2008 11:50 AM
stunner82
Nov 25, 2007 02:53 PM
