ECM 94 Fleetwood
Old Aug 28, 2009 | 10:35 PM
mojazz1231's Avatar
Default ECM 94 Fleetwood
ECM 94 Fleetwood
Where is the ecm located undash of 94 Fleetwood? Driver side center middle or passenger side of vehicle?
It shut down on me while I was driving, had to have it towed. replaced the fule pump and coil (was told that was problem by chevy repair shop). Fired the starter when I placed fuel pump becuse of connection to pump was not hooked up.
Replaced starter. Started but had a hesitation, (jerking type action), when trying to maintain speed but felt good/great while acclerating but then stopped on me again while driving after a month or two.
Replaced cap, roter and electronic module in distributor, will not start.
Coil is not getting spark so I guess it's got to be the ecm.
Old Aug 29, 2009 | 06:07 PM
I will be surprised if ECM fixes it. ECM controls injectors more so than spark at start up. You need to re-eval ignition system.
Old Aug 30, 2009 | 01:46 AM
mojazz1231's Avatar
Now I'm at a loss. What else could cause no spark after all I have replaced?
Old Aug 30, 2009 | 01:52 AM
mojazz1231's Avatar
Default 94 fleet ecm
Old Aug 30, 2009 | 08:57 AM
Are you using a manual to figure it out or guessing with parts? New parts can fail and LT1 distributor being behind water pump and low in vehicle is subject water/coolant intrusion. Are there any codes stored.
mojazz1231
Aug 28, 2009 09:25 PM
carlosm1974
Dec 5, 2006 07:52 PM
Stardog
Nov 12, 2006 04:31 PM
kscaddyguy
Sep 4, 2006 04:40 AM
turbo90gp
Aug 24, 2005 10:35 PM
