Dash codes
Old Apr 12, 2007 | 02:15 PM
Pilot's Avatar
Default Dash codes
I have a 95 STS and am getting a "code 88" on the dash display, The ABS and traction control disengage (shows on the dash display)when this code is displayed. It occurs about 5 mins after I start driving and will go out if I shut down and restart but comes back again. Any ideas? Thanks
Old Apr 12, 2007 | 03:37 PM
belagatyo's Avatar
Default RE: Dash codes
You can find OBD-I information here: http://myweb.accessus.net/~090/dtcobd1.html
P088 (E088) .... Torque converter clutch did not disengage when commanded OFF by PCM
I would guess this is similar to the OBD-II TCC Stuck On situation, where the most likely causes are debris/obstruction in the tranny or internal leaks.
Old Apr 12, 2007 | 03:42 PM
Pilot's Avatar
Thanks so much. Any idea what I can or should do about it to try to trouble shoot or fix.
Old Apr 12, 2007 | 07:59 PM
belagatyo's Avatar
Beside checking the fluid for sediments, not a whole lot you can do. The dealer or a tranny shop with a Tech-2 can do a thorough diagnosis and recommend action. This could be as simple as changing the fluid, or replacing a failed part or seal, or...[:'(]
Margo1313
Jul 14, 2009 02:25 PM
dfb52764
Aluminum Block V8s
Jan 11, 2009 09:50 PM
LGT Automotive.com
Aug 25, 2005 03:20 PM
LGT Automotive.com
Aug 25, 2005 03:11 PM
toms46
Nov 14, 2004 04:34 PM
