new here with questions on a 93 deville obd1 codes
Old Apr 10, 2007 | 02:30 PM
lenny lincoln's Avatar
Default new here with questions on a 93 deville obd1 codes
Hello all great site. I have recently purchased a 93 deville with 130k , The battery was dead when i bought it. After recharge i found a check engine and a SSS light on. I had a guy run the obd1 test on the climate control panel and only got a 188 code. I couldnt do it because the car is 150 miles from me. the car starts and runs fine but i want to get things fixed prior to bringing it home. I know that the sss light is the suspension and probaly the struts gone south . I will do the wire snip and wire patch for that. but I would like to know whats causing the check engine light and the 188 code? any ideas??
Old Apr 13, 2007 | 10:02 AM
belagatyo's Avatar
Default RE: new here with questions on a 93 deville obd1 codes
The code and the SES light may be related, but are you sure it's 188? I cannot find it in http://myweb.accessus.net/~090/dtcobd1.html
banderson
Oct 27, 2010 05:43 PM
dfb52764
Aluminum Block V8s
Jan 11, 2009 09:50 PM
Capriceman76
Nov 30, 2007 10:43 PM
theatreman
Nov 21, 2006 12:52 AM
