Cadillac CTS Service Question: Break Lights out..bulb or fuse?
I realize that this may sound like a silly question, but today a driver stopped me and said both my brake lights were out. She said the top light(CTS) was still working but both tail lights were out. I had no idea and I tried to figure out if all the brake lights are on the same fuse and is it worth it to change the fuse box or if I should run right to service and have them change the bulbs to see if this is the problem. The last thing I need is to be overcharged for something that requires a minimal amount of money. Any thoughts?
moderator edit:
title
moderator edit:
title
did you check the bulbs? seems weird both would be out..... follow wires especially from top light, to sides. see if they connect somewhere.......
good luck
rickd
good luck
rickd
Dont know if i tmakes any difference but what year model you got?
ORIGINAL: 6ftladycop
I just posted in the wrong spot and then I found you guys. While driving today, somebody stopped me and said both brake lights were out. Of course I was immediately upset and did not know if it was a fuse or a bulb problem because my CTS top brake light is still working. I need to go to service but worry about being charged an absorbent amount of money for a simple procedure and wondered how to tell the difference. Does anybody here have knowledge of this type of problem? I sure could use the help as the holidays are coming and getting an appointment with the Cadillac dealership is almost next to impossible.
Also, is it ever a good idea to allow other mechanics to service your Cadillac while its still under warranty...even for something so small as a fuse change or bulb change?
