A/C problem with new engine
Old Jul 27, 2008 | 05:20 AM
adixon3's Avatar
Default A/C problem with new engine
I had a blown head gasket on my 99 deville N* engine so i replaced it with a N* engine from a 2000 deville but the problem is i can't get the ac to work correctly every time i try to put it in auto it switches to econ. i had the mechanic that installed the engine check the system and it was full of freon but the ac clutch is not getting any power going to it. Do I need to replace the 99 PCM to a 2000 PCM because of the new engine so everything is recognized works correctly or is there something else that needs to be done?
Old Jul 27, 2008 | 03:24 PM
carnut's Avatar
Default RE: A/C problem with new engine
My first thought is there are A/C fault codes in the BCM. Enter diagnostics and erase all codes. report back
Old Jul 30, 2008 | 02:45 PM
adixon3's Avatar
I cleared all the codes and the ac still does not work
Old Jul 30, 2008 | 07:32 PM
You will need to check the basics, something disconnected, fuse(s), etc. There are alot of electrical items under black plastic cover near left front strut tower. I would start there.
Drama
Oct 6, 2020 09:45 PM
taf
Aluminum Block V8s
May 6, 2009 09:25 PM
RiceH8TR
Mar 24, 2008 08:03 AM
