battery no charge message
Old Feb 10, 2008 | 03:47 PM
lksockey's Avatar
Default battery no charge message
I have a 93 STS Seville Northstar - battery is less than a year, replaced alternator 6 or 7 months ago. This morning the info screen came up with Battery No Charge message - car started fine, but this message comes up after starting. (when the alt went out it did not give any type of message, just died and would not start- had to be towed) I have checked the battery connections, seems to be OK. When the key is turned on and I press the Info button, it will show 11.7 or 11.8 volts on the battery (usually around 13 volts shows). Any suggestions or ideas.
Old Feb 11, 2008 | 10:14 AM
Default RE: battery no charge message
lksocker, first, welcome to the Forum..... second, with key on and car not started, 11.7 / 11.8 is normal reading. what is reading when sts is running?13.6,7, to 14.2 would be normal let the Forum know, and we'll get back. good luck
Old Feb 11, 2008 | 11:17 AM
lksockey's Avatar
When the engine running and I press info it does nothing - will not display the charge - the "Battery No Charge" stays on -
Old Feb 11, 2008 | 07:37 PM
You need to have charging system tested. Some auto parts store will do it for free. Also check for codes, some alternators are controlled by ecm.
HAMMbone89
Feb 16, 2015 11:36 PM
P_Mac
Vintage & Classic Cadillacs
Jan 12, 2011 02:05 AM
CaddyDaddy99
Mar 25, 2010 06:48 PM
moniqueindo
Feb 2, 2010 10:27 AM
tsandel
Mar 27, 2009 08:40 AM
