A.B.S. trouble. Please help!?
Old Nov 18, 2007 | 08:02 PM
Plakos's Avatar
Default A.B.S. trouble. Please help!?
I have no first gear because my A.B.S. is not working (niether is my ride control or my traction control). The car is a 95' STS and the codes are:
T061- low brake fluid
T083- motor pump circuit
The car has plenty of brake fluid so the sensor is bad and I am guessing the other one is the A.B.S. pump. Can anyone tell me how to tell if the pump is bad? how do I test it? I have a complete 1995 or 96' Deville with a northstar (My family owns a scrap processor and somebody junked one yesterday)so I guess I can use that one if it is bad, (the pump).
Also, Before I process the Deville, are there any parts from the Northstar that I should take, just in case??
Alex
Old Nov 18, 2007 | 08:54 PM
Default RE: A.B.S. trouble. Please help!?
welcome to the Forum Plakos..... sort of slow around here tonight..... hang in, check back.. i'm sure a the righttech will be by soon. ......... have you been to member introduction? or, be counted in Cadillac demographics, how old are we?............... look around, check it out, tell the Forum about your ride,..... got pics? good luck with it
Old Nov 18, 2007 | 11:37 PM
ORIGINAL: Plakos
Alex
I be pulling the whole engine'trani, with all accesories before the crusher gets to it.
Your codes seem to be backwards? This is what i get:
T061- brake relay failure code
T083- low brake fluid
Did your service suspension warning light come on also? need new shocks?
you may want to get your vehicle hooked up to a scanner, read the trouble codes computer is throwing out.
It could be something as minute as a non-working sensor or $1,000 of work.
Old Nov 19, 2007 | 12:27 AM
Plakos's Avatar
YES but what do shocks have to do with ABS and first gear??
Old Nov 20, 2007 | 09:13 PM
nothing
Cadillac Al
Nov 30, 2008 02:56 PM
chocolate24
Mar 16, 2008 05:22 AM
mrcrx28
Mar 13, 2008 05:32 PM
Capriceman76
Nov 30, 2007 10:43 PM
brougham1
Mar 12, 2007 11:13 PM
