Anyone pulled a 4t80e transmission ??????
Old Jun 11, 2007 | 07:06 PM
l306x's Avatar
Default Anyone pulled a 4t80e transmission ??????
ok i started to pull the trans out of my 94 sts today i cant get the drivers side cover off .do you need to get the trans out to get it off? it looks like it has some bolts behind it that need to come out to drop the trans. i just cant get to them with that cover on
thanks for the help
Old Jun 12, 2007 | 06:20 PM
FLCaddytech's Avatar
Default RE: Anyone pulled a 4t80e transmission ??????
I'm not really following you all that well, but no, the side cover does not need to be removed until the trans is out of the car.
The top 2 bellhousing bolts are under the throttle body behind the wiring harness. difficult to see 18mm head.
The rear bellhousing bolt (15mm head) is hidden.
Some find a way to get it from the top, others (me) from the bottom.
Either way you can't see it, only feel it.
I use a short 15mm ratcheting wrench, although its tough to break the bolt loose some times.
The front bell bolt is the only one that is easy to get to. it's 18mm head also
tom h
Aluminum Block V8s
Jun 14, 2011 04:26 PM
Margo1313
Jul 14, 2009 02:25 PM
ktowncaddy
Jan 11, 2008 08:47 PM
cortewardy
Automatic Transmissions
10
Oct 24, 2007 01:16 AM
VIN9
Aluminum Block V8s
Sep 19, 2007 09:18 PM
