air conditioner
Old Oct 7, 2008 | 02:33 AM
groce45's Avatar
Default air conditioner
i replaced clutch & pulley. now comppresser won.t kick in. message: low freon, compresser off. is there a relay or fuse?
Old Oct 8, 2008 | 12:47 PM
carnut's Avatar
Default RE: air conditioner
Erase all A/C related codes. Assuming its full of freon, it should engage. I believe it says how to service the system on the yellow underhood decal.
Old Oct 8, 2008 | 12:55 PM
groce45's Avatar
thanks carnut, how do i erase codes?
Old Oct 15, 2008 | 01:23 AM
Texan4Life's Avatar
Just disconnect and reconnect the ground on the battery.
OR you can do it from the climate control panel.
IF it is like mine it would go like this:
You push OFF and WARMER at the same time. and then where the fuel data is display it will flash codes. when it stops and says .7.0 then press OFF and LO at the same time and it should then display F.O.0 which clears the BCM codes. Then hit OFF and HI at the same time and it should show E.O.0. (clears ECM codes) and then in a few seconds should switch back to .7.0
gsteward
Aug 3, 2008 12:03 PM
h.fork
Sep 21, 2006 02:39 AM
brougham1
Jul 17, 2006 03:36 AM
brougham1
Jul 17, 2006 03:35 AM
gsteward
Jul 5, 2005 01:49 PM
