Air Conditioner doesn't come on
Old Jun 16, 2005 | 10:08 PM
gsteward's Avatar
Default Air Conditioner doesn't come on
I have a '96 Devil and the AC control will not switch form "ECON" to "AUTO", so the AC pump never comes on. When I push the "AUTO/ECON" button, the LED shows it switching to AUTO, but as soon as I let go of the button it goes back to ECON. One day it was working fine, and then suddenly it didn't, so I am thinking it is an electrical issue. I checked the refirgerant level and it is good. Fuses in the fuse box are good. I replaced the AC relay in the fuse box just to be sure. So all the easy fixes have been tried.
** Update on the problem**
I disconnected the battery for a few minutes, to reset the computer, and the A/C worked normally for about an hour, then the problem returned (it was a very hot day, for Denver Colorado). I reset the computer again, and now it has worked for two days, which amounts to about 3 hours of my wife cruising around town.
What could be causing this????
Old Aug 2, 2008 | 02:01 PM
cadillacstyle's Avatar
Default RE: Air Conditioner doesn't come on
I had that problem about three weeks ago, i had my ac converted over to the 134a. but the ac never came on, even on defrost it never came on. then i found out that computer needs to be cleared of fault codes. so i got info on how to clear. then the ac come right on. hope it helps you. Cadillacstyle
Old Aug 2, 2008 | 02:55 PM
carnut's Avatar
If you have no codes, you are low on freon!!
Old Aug 3, 2008 | 12:03 PM
brougham1's Avatar
Could also be your Ambient sensor or the in car sensor, which is for temp. set.
jmoffo
Apr 15, 2007 10:20 PM
h.fork
Sep 21, 2006 02:39 AM
brougham1
Jul 17, 2006 03:36 AM
brougham1
Jul 17, 2006 03:35 AM
gsteward
Jul 5, 2005 01:49 PM
