99 seville sls died at idle
Old May 20, 2008 | 03:45 PM
BlakeF's Avatar
Default 99 seville sls died at idle
I'm a new cadillac owner and saw this forum and my eyes lit up! So i bought the car a couple of days ago and had no problems. Was driving it home (about a 3 hour drive) and i had about 30 minutes left to the house and it died on me as i was giving it gas at a intersection...wouldnt start back up, would turn the key to the on position, and everything was good, tried to start it up and the dash lights turned off. Everything worked fine until i would try to start it up.This went on for about 5 minutes, then started back up as if nothing happened. Really puzzled me. Have the car at a local mechanic right now but he says he cant find anything wrong with it. Would REALLY appreciate some of you alls cadillac expertise! Thank You
Old May 20, 2008 | 04:01 PM
2001slswhite's Avatar
Default RE: 99 seville sls died at idle
Not a expert but sounds like a bad battery connection. Either the positive wire orthe ground wire are not getting good contact.
Old May 20, 2008 | 10:06 PM
imo, Starter.... does the starter operate slow when it does start?
good luck... keep us posted
Old May 21, 2008 | 12:33 AM
BlakeF's Avatar
no, the car starts up great. I'm going to have the car back tomorrow and i will check it out.
Old May 21, 2008 | 10:21 AM
ORIGINAL: BlakeF
you are describing a classic "ground issue" .. start at the battery, remove grounds, clean, apply di-electric grease and reconnect.
the next suspects would be a faulty alternator, old/weak battery.
there is a lot of valuable info on the threads below, but the e-ghost thread should be of special interest to you.
also, jump into the fun threads in the Off-Topic or the Allante Pub.
The BEST car Cadillac ever made is the .. you get to pick.
https://www.cadillacforum.com/m_9438/tm.htm
MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars.
https://www.cadillacforum.com/m_12353/tm.htm
CODES .. Pulling & understanding CODES .. we need CODES to help you.
https://www.cadillacforum.com/m_18197/tm.htm
https://www.cadillacforum.com/m_17425/tm.htm
https://www.cadillacforum.com/m_11904/tm.htm
Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture,
Corp 800 #’s, unique shipping services .. etc ... take a look.
https://www.cadillacforum.com/m_9880/tm.htm
Average age of our Cadillac owners .. where everyone says they are 23.
https://www.cadillacforum.com/m_931/tm.htm
Why you should change to coolant the day you buy the Cadillac.
https://www.cadillacforum.com/m_7193/tm.htm
https://www.cadillacforum.com/m_7388/tm.htm
Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains.
https://www.cadillacforum.com/m_6036/tm.htm
Cadillac GM e-ghosts electric problems, intermittent codes, etc.
https://www.cadillacforum.com/m_6068/tm.htm
Help from our TECHs ? You really want to read this.
Cadillac TECH FAQ MENU .. pull up all the FAQ topics
https://www.cadillacforum.com/m_6733/tm.htm
Cadillac Technical FAQ section .. everything Cadillac
https://www.cadillacforum.com/forumid_64/tt.htm
Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc.
https://www.cadillacforum.com/forumid_83/tt.htm
The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in.
https://www.cadillacforum.com/m_21055/tm.htm
Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle
https://www.cadillacforum.com/m_18287/tm.htm
Hobby Corner .. Hot wheels, trains, whatever ..
https://www.cadillacforum.com/forumid_60/tt.htm
Cadillac History .. The real McCoy, from day one.
https://www.cadillacforum.com/m_6356/tm.htm
Welcome to CadillacForuM.com
Old May 21, 2008 | 02:08 PM
BlakeF's Avatar
so i just got back from the mechanic to pick up the car...AND IT WOULDNT START!!! just like what happened after it died. It would lose ALL power whenever i would try to start it up. He keeps telling me its the starter, but it wouldnt lose all the power like that if it was the starter would it???? HELP ME PLEASE!
Old May 21, 2008 | 02:20 PM
BlakeF's Avatar
and he had just got back from driving it around town a little bit.
nicbrown
Dec 11, 2009 09:09 PM
fabes
Oct 29, 2009 12:05 AM
O1ETC
Jan 23, 2007 08:34 PM
daniel0015
Jul 10, 2006 08:08 PM
