99 seville sls
Old May 22, 2008 | 11:48 AM
BlakeF's Avatar
Default 99 seville sls
So i pulled some codes and this is what i got.... DDM U1225, IPC B1652, PCM P0607, PCM P1599, RIM U1255, VTP B2947....any help??
Old May 22, 2008 | 03:49 PM
Default RE: 99 seville sls
so what is your car doing? were these codes in history, or current? we need a little more info if your having a problem. the codes could have been in there for a while.... get back to the Froum with more info.
there are many posts in the Forum that explain the codes.....look around
Old May 22, 2008 | 04:27 PM
BlakeF's Avatar
I checked the codes out and this is what i have found ECU malfunction, Engine stall or near stall detected, class 2 comm. malfunction, security system sensor power circuit low, loss of comm. with PCM, and Keep alive memory, it doesn't say history or current?...but i just pulled up the codes again and it didnt give me any. I haven't had any problems with the car today at all.
Old May 22, 2008 | 07:33 PM
okay, sounds like you reset your codes, and ....well thats not so bad. lets see what goes on from here. check codes daily to see if any show up. has the sls ran bad, and now its running ok??
Old May 22, 2008 | 09:45 PM
BlakeF's Avatar
The car runs great. it'll just stall out everyonce in a while, but only when im stopped. Didn't stall out once today. I've had the car for a couple of days now and i love it, nothing rides like a cadillac!!
house1000sleeved
Aug 12, 2007 02:05 PM
ondrece1
Sep 27, 2006 11:32 AM
Nick
Nov 20, 2005 03:39 PM
fleishman
Jun 2, 2005 04:40 PM
Mugerjr
May 2, 2005 04:22 PM
