94 STS code P119 next step techs?
Old Nov 18, 2007 | 07:38 PM
  #11
Plakos's Avatar
Default RE: 94 STS code P119 next step techs?
before you do anything else, I had that code and it ended up being my fuel pressure regulator!!!!! I have a 95'STS. While the car is running, pull the vacuum from the FPR. If there is any gas there, even a tiny but. Then it is bad and you are sucking gas......I know it's like $118 but my car runs so much better now it was like night and day....
Alex
Old Nov 19, 2007 | 07:30 PM
  #12
jrs12304's Avatar
the 94 has theFPR in the intake (no vac. hose) but I will look into it ..... I did all the diagnostics from the servive manual and #6 injector was not getting ground from the pcm......but i will look into the FPR a little more. thanks
Jun 22, 2023 11:21 AM
Tyrone Harper
Oct 7, 2014 05:55 AM
BiH
Sep 3, 2007 08:13 AM
