94 sts clear codes
Old Nov 3, 2007 | 08:29 AM
handyboyski's Avatar
Default 94 sts clear codes
how do I clear the code on my 94 sts.
Old Nov 3, 2007 | 08:51 AM
Default RE: 94 sts clear codes
HAVE YOU RAN CODES?.........ON MY '99 STS, AFTER I RUN CODES, IT WILL ASK IF I WANT TO "CLEAR ALL CODES"
CHECK IT OUT
HOPE IT HELPS
Old Oct 14, 2008 | 02:00 AM
groce45's Avatar
does anyone know how to turn-off traction control light on 97 reviera?
Old Oct 14, 2008 | 09:50 PM
DAN S's Avatar
press the "off" and the temp increase button on your climate control at the same time.that will get you into the diagnostics system.After it runs through,it will ask for specific system.PCM?ICP? etc.On each one press the fan increase button until you get to "clear codes".Press the fan decrease to clear codes.If it's a current code it won't clear til the problems fixed.
Old Oct 14, 2008 | 10:17 PM
DAN S's Avatar
Forgot to mention,if you have any questions on diagnostics or codes logon to "awh cadillac resources" it will show you how to get into all the diagnostics and what the codes mean.
Old Nov 7, 2008 | 10:14 PM
NAFTA's Avatar
I'm back....It's been a while and my Caddy clowned me It turned off on me and everything else with it because my sound system killed the alternator. Power steering got turned off, the dash went off with the gauges, brake was hard to use and the transmission was acting weired - basically everything went dead because the batter fell under 9 volts. I had all these codes and then I took out the batter to get it fully charged to get to the dealer. I fully charged the battery to 700 CCA and it took me only 4 blocks before it did the same thing. I finally had the Eldo towed to my shop and had the alternator replaced. I havn't had any problems with it since, but I check my onboard diagnostics and I seen some codes on there and was suprised that they couldn't be cleared after the scan. I had a lot of codes before the shop because of the alternator - Battery voltage too high at first, then battery voltage too low, then battery not charge, and then it died. Now I have a few codes that I don't know how to clear, but after the code it says HISTORY. I have P052 HISTORY, P109 HISTORY, T085 HISTORY (which I couldn't even find out what it means), and I052 HISTORY. Can anyone help me and maybe tell me a way to clear them if they arn't current because it doesnt display clear codes by itself at the end. Thanks, I appreciated it.
Old Nov 8, 2008 | 03:03 PM
NAFTA's Avatar
Can anyone help here ?
2005caddy
Jul 8, 2009 12:36 PM
dfb52764
Aluminum Block V8s
Jan 11, 2009 09:50 PM
dadsbadbuick
Oct 13, 2008 10:06 AM
manchutiger
May 1, 2008 06:31 PM
