93 STS Running very rich
Old Mar 15, 2007 | 05:27 PM
bpeesy's Avatar
Default 93 STS Running very rich
Help, I have a 93 Seville STS with the Northstar 160k. It is running very rich all of a sudden.I thought it was just a plugged Cat since it was glowing, It's running so rich it has the new Cat glowing underneith the car. I found that I had a leaky injector so I replaced that one. the car is still running super rich. I'm down to 10mpg. the codesall show history, the only current code is t037 lr speed sensor. I tried clearing codes by disconnecting the battery & removing the ecm fuses, but the same codes are there when I hook the battery up,(severalhistory codes, and the 1 current code). I noticed that when I lift the fuel rail nothing comes out of the fpr but fuel squirts out ofthe other tube (next to the wire harness) . Idont knowwhat it's called. Question -- could it be the fuel pressure regulator that's causing fuel tosquirt from that other line? Other than running rich, & burning up my Cat it runs great. Help!!! Thank you
Old Mar 15, 2007 | 07:33 PM
Default RE: 93 STS Running very rich
not familiar with the N*, but an engine is an engine and
a ECM is a ECM.
read on ..
lol
ORIGINAL: Stealth
wet or black with soot means rich fuel mixture,
you may also exerience smoke upon start up and very rought idle.
not sure this applies anywhere here but i had my 4x4 with a simialr problem
and after months of testing i found a bad sensor -- of all things, the coolant
sensor was dead
and the ECM interpreted that as the engine being cold and
enriched the mixture. $20 later with new sensor all back as it should.
ORIGINAL: snapmech
its gets too much fuel the plugs are wet ?
Old Mar 15, 2007 | 10:53 PM
bpeesy's Avatar
The temperture sensor seems to be ok. I get a correct reading. I have checked all other fuses to no avail. Is there a way to test the Fuel Pressure Regulator on this car?
Old Mar 24, 2007 | 12:31 PM
i know you can check the pressure of the fuel delivery ..
fuel presuure gauges at auto parts stores not so expensive.
the regulator? i have no idea how to check those
also, a fuel injector may be stuck partially open?
Old Mar 24, 2007 | 02:05 PM
until this day, i was not aware that in '93, the N* had found its way to other models
besides the Allanté. ElDorados are confirmed as now you show the STS.
thanks
Old Apr 6, 2007 | 03:38 AM
bpeesy's Avatar
I havea 93 Seville STS --and I am definately sure that ithas to Northstar Engine in it. I have had a few caddy's in the past. Iam 100% sure that this engine with the bigaluminum plenum is theN* -- besides my other 92 Deville has the 4.9. I have just purchased 8 new fuel injectors -- hopefully this will cure the car from running so rich - otherwise it still runs great.
Old Apr 6, 2007 | 03:59 AM
there is confussion on the '93 models for reports of N* engines.
based on your original post, i went on a search and found that some '93 ElDorados
also had the N*.
i'm still trying to figure out when in '93 the N* showed up on other models.
sorry about that ..
editing my post above to correct ..
Jul 29, 2009 12:34 PM
matter
May 11, 2009 03:10 PM
jasper60103
May 2, 2007 09:56 AM
bcleachd
Jun 28, 2006 01:08 PM
MetalTeK
Mar 9, 2006 05:35 AM
