92 STS Overheating
Old Apr 7, 2008 | 05:24 PM
zyzzle's Avatar
Default 92 STS Overheating
I have a 92 STS with 125000 miles. I believe it has a blown headgasket, cracked block or cracked/warped head or any combination of the above. It intermitently overheats, is loosing coolant and appears to lose some coolant in the oil. I have seen advertized several products which claim to repair these problems, most are in the $100.00 plus range. Has anyone ever used any of these type of products successfully and if so, which one? I do not want to tear down the engine. Any help will be appreciated. Thanks
Karl
Old Apr 8, 2008 | 08:53 PM
Default RE: 92 STS Overheating
Most likely intake gasket, 4.9 is alot more inexpensive to fix than Northstar. I would stay away overhaul in a can. Head gaskets don't fail very often on the Cadillac push rod engines, with proper maintanence.
Old May 8, 2008 | 02:22 PM
ORIGINAL: zyzzle
Karl
Did you get the new head gasket? for our info, what did it cost?
officerbear
Aug 26, 2016 05:48 PM
ladyadt
Sep 1, 2012 11:21 PM
CaddyWoes
Jun 23, 2009 11:01 AM
Caddyman77
May 8, 2008 02:20 PM
jamacias
Apr 24, 2007 09:52 PM
