71 deville ignition switch removal
Old Feb 26, 2007 | 04:18 PM
mikew's Avatar
Default 71 deville ignition switch removal
How do I remove the ignition switch?
There is a broken off key in it
I have removed the steering wheel and the turn signal switch
There seems to be no logical next step
Ideas/suggestions
It has cruise control if this makes any difference
Old Feb 26, 2007 | 10:52 PM
fleetwood chuck's Avatar
Default RE: 71 deville ignition switch removal
HELLO, TO REMOVE THE SWITCH YOU MUST REMOVE THE COVER AROUND THE STEERING GEAR SHIFT LEVER TURN THE SWITCH TO THE ACC POSITION THEN UNDER THE SWITCH HOUSING THEIR IS A PIN THAT MUST BE PUSHED IN WITH A SMALL PIN PUNCH TO RELEASE THE SWITCH THEN PULL OUT ,
Old Feb 27, 2007 | 09:37 AM
mikew's Avatar
Thanks, I know more now thanI did then.
Unfortunately, I can't see how to remove the steering column housing.
Also the broken off key prohibits any chance of turning
mw
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
nunezm08
Dec 11, 2012 08:53 PM
rmichaelhanna
Oct 5, 2010 07:14 PM
70coupe
Sep 9, 2009 09:24 AM
