2009 cts v 6 #4 cylinder miss fire under load
Old Jan 7, 2017 | 12:19 PM
Jimkidmotorsports's Avatar
Default 2009 cts v 6 #4 cylinder miss fire under load
I have a miss fire just under load number 4 cylinder 3.6 di replaced coil and plug fuel pressure good
Old Jan 7, 2017 | 05:09 PM
Compression test. Is injector getting pulse? there is no easy way to check if injector is spraying. you could disconnect the other 5 crank engine and see in fuel pressure drops.
Old Jan 8, 2017 | 07:31 AM
Compression good engine will rev up okay after like 2000 rpm no problem
bubblesdad
Dec 13, 2009 11:10 PM
plat850
Nov 28, 2007 09:39 PM
Jun 26, 2007 04:25 PM
JIMRUN
Mar 30, 2007 07:27 PM
