2008 Cadillac CTS
Old Apr 15, 2020 | 07:18 AM
unconspicuousghost@gmail.com's Avatar
Default 2008 Cadillac CTS
I have a quick question. My check engine light was on. Had it read at Autozone. It said my cylinders 2,4,6 were misfiring. So, I replaced all 6 spark plugs and put new ignition coils as well replaced two of the camshaft sensors. Clear codes and ran it for 100 miles. It’s still reading I’m having a misfire for the same cylinders 2,4,6. Do y’all know what that might be?? Some say it’s the timing chain and it’s sniping a tooth. If so, can that be it? Is it worth fixing? Thank you.
Old Apr 16, 2020 | 10:56 AM
Rowdy Yates's Avatar
How many miles do you have on the car ? And what engine is it? If it is a V6 and those cylinders are all on the same side I think you are closer to an answer.
Old Apr 16, 2020 | 01:40 PM
Default Hello. Thanks for responding.
I have 162,000 on the caddy. It’s not a straight 6. It is a V6, 3.6L.
Old Apr 16, 2020 | 01:58 PM
Default Also, another thing.
I had the engine rebuilt like 6 or 7 months ago. Spent $3,800 on it.
Sending a pic of my engine. It has 3 spark plugs on each side of engine.
Old Apr 16, 2020 | 05:34 PM
2,4,6 is the cylinders on the right side of the engine (drivers side). That could mean a right side timing chain issue, a sensor, or a third possibility. You said the engine was rebuilt 6 or 7 months ago? I would check and see if they put in new timing chains on. What did they rebuild?
Old Apr 16, 2020 | 08:40 PM
Default Replying to Rowdy Yates
I don’t know exactly what they rebuilt. I had asked him. He said the timing chain was fine when they rebuilt the motor. But, they had taken apart my engine completely and rebuilt the engine.
Old Apr 16, 2020 | 08:59 PM
well i think for $3800 its not unreasonable for you to know what they did for your rebuild. After 6 or 7 months you should not have to change a timing chain. A timing chain kit is roughly $175 plus labour. If they removed the engine, did pistons and rings along with valves and valve springs, the timing chain should have been done since it is now 4-6 hours of labour to do that job for sure. When they remove the heads to do whatever rebuild they did, they would have to remove the timing chain anyhow.
Getting back to your original question, it sounds to me like a timing chain issue. If i were you, I would talk tot he rebuilder first. The common denominator for all 3 cylinders on the right side is pointing to a timing chain. The rebuilder has some splainin to do.
Old Apr 17, 2020 | 09:50 AM
Default Thank you so much!!!
Yes, I’m going to do that ASAP!! Im in Houston Tx and the drive back to my hometown is 5 hours away. So, I’ll be heading down there to talk to them and bring my car back to them. Will do it I’m next week when I get laid off from my job here. Again, thank you so much for replying. God bless.
Old Apr 17, 2020 | 10:08 AM
Dont delay. the engine is liable to quit on you. God speed.
nicther
Sep 14, 2019 05:54 PM
papasmurf745
Apr 24, 2019 01:40 PM
Joe Engineer
Oct 17, 2017 01:29 PM
cadillacmike343
Jan 10, 2016 11:32 AM
DesignerElise
Aug 12, 2014 04:03 PM
