2000 seville won't turn over
Old Sep 30, 2007 | 04:48 PM
mreperf's Avatar
Default 2000 seville won't turn over
With no signs of a problem before, my STS seville wouldn't turn over. When you turn the key the cluster panel goes out and there is a definite click on the starter but doesn't engage.The headlights do not go out at any time.I've checked all battery connections and the starter relay in the fuse panel clicks also. I'm just trying everthing before I pull the manifold for nothing. Any ideas? Thanks
Old Sep 30, 2007 | 08:10 PM
Default RE: 2000 seville won't turn over
mreperf......welcome...... please check out Member Introduction on the site, check things out there............theForum can help you, with no problem.
later......... again welcome!
Old Oct 1, 2007 | 09:45 AM
brougham1's Avatar
mre, I'd be checking the starter ground and the solenoid. As long as fuse and relay check out. Jumper the starter with a hot wire to make sure it spins then you will know if it's solenoid for sure.
con
Oct 2, 2015 01:31 PM
bryanmilio
Apr 24, 2015 04:40 AM
tla528
May 24, 2014 10:38 AM
wpstore
Feb 5, 2010 05:59 PM
