2000 DTS with Code # P0741
Old Jul 28, 2007 | 07:07 PM
Default 2000 DTS with Code # P0741
it was posted elsewhere and i moved it to a better place.
ORIGINAL: Dorsey
Hi I have a 2000 DTS and it runs great. The problem I have is the radio will not come on. The screen lights up, the clock and the gps work but no sound. I checked the fuse under the dash and the larger on in the trunk, both are ok. I did however replace the smaller fuse the one under the hood as a test, still not working. I also checkedfor codes with my OBD2 to see if anything showed up regarding the radio. Nothing about the radio but Code # P0741 came up. Torque converter stuck off or Preformance. Can you explain, because the car runs fine no codes have poped up. The only way I knew it was there is because I was looking for something else. Any help appreciated, Thank you!!
Old Jul 30, 2007 | 09:36 PM
eothrash's Avatar
Default RE: 2000 DTS with Code # P0741
was there a recall on thisP0741&P1860 code? eothrash@yahoo.com
Old Jul 30, 2007 | 11:18 PM
ORIGINAL: eothrash
was there a recall on thisP0741& P1860 code?
P0741 was a transmission code about the torque convert unit
and a solenoid that may or may not be bad.
i be clearing the codes and see if it repeats.
recall? i dont know.
bbusse
Automatic Transmissions
Mar 2, 2013 01:19 AM
fordmodelb
Mar 1, 2012 08:13 AM
tedalmeida
Aluminum Block V8s
Jun 14, 2009 08:26 AM
TJAXFF
Jan 12, 2008 08:34 AM
datdude
Feb 11, 2007 12:56 PM
