Code P0741
Old Jan 10, 2008 | 09:04 AM
TJAXFF's Avatar
Default Code P0741
My check engine light is on, and I'm getting code P0741, I know that it says Torque Convertor clutch switchstuck on. My question; Is this a complete tranny teardown to repair? Or is it an external switch that can be easily replaced? Either way, would anyone have an idea of the price for the repair, whatever it involves. I have a 98 Eldo with 65K on it. Thanks, TJ
Old Jan 10, 2008 | 11:54 PM
Default RE: Code P0741
ORIGINAL: TJAXFF
such codes are usually related to a switch or solenoid and there is usually no need to overhaul or tear down the trani.
these items are often replaceable by way of access covers.
Old Jan 11, 2008 | 06:42 PM
With your mileage should be a repair. It does have to diagnosed I cant give you a for sure on what you'll need, but figure 800.-2k reman trans installed 3-4.3k .Parts and labor will vary depending on your area and shop. Well under 100k miles overhaul is likely a rip off. No external switch to replace.
Old Jan 12, 2008 | 08:34 AM
TJAXFF's Avatar
Slowroll: Thanks for the info, it's pretty much on the money. My mechanic (a good one) repeats what you stated. Says between $800-$1200 for what has to be done to get to & replace the bad switch, also has to do something to the plates in the torque convertor. Gonna go for the fix!
Thanks Much, TJ
bbusse
Automatic Transmissions
Mar 2, 2013 01:19 AM
fordmodelb
Mar 1, 2012 08:13 AM
tedalmeida
Aluminum Block V8s
Jun 14, 2009 08:26 AM
Jul 30, 2007 11:18 PM
datdude
Feb 11, 2007 12:56 PM
