2000 Deville base model no start
Old Dec 20, 2011 | 08:35 PM
  #11
brianlofton's Avatar
i did clear all the codes before i programed the new key
Old Dec 20, 2011 | 08:52 PM
  #12
gmtechs's Avatar
are u using the on board system to check for codes or using a code reader
u did the three 12 minutes relearn then turned off vehicle then tried to start and no go
is the security light on or off
after u turn the key does it stay on
sometimes doing it the way u did it does not always take it the first time
Old Dec 20, 2011 | 10:06 PM
  #13
Im using the onboard reader... the security light is acting as it should now... not on when the key is in the ignition... after the third cycle it volunteered that the starter was disabled in the display... i am trying the three cycles again...
Old Dec 21, 2011 | 08:49 AM
  #14
and there is a clicking noise now when the tumbler is moved to the start position... but still no start... could it be the theft deterent module... by the by i did a onboard code read today and the AMP, IPM, IPC and RCC circuits all report a b1004 code current...
Old Dec 21, 2011 | 02:03 PM
  #15
im sorry the rcc was b1009
Old Dec 21, 2011 | 11:55 PM
  #16
gmtechs's Avatar
If this DTC is retrieved as either a current or a history DTC, replace the module.
Step
Action
Value(s)
Yes
No
Did you perform Diagnostic System Check - Body Control System ?
Go to Step 2
Go to Diagnostic System Check - Body Control System
  1. [*]
Is DTC retrieved as a current or a history DTC?
Go to Step 3
Go to Testing for Intermittent and Poor Connections in Wiring Systems
Replace the module.
Did you complete the replacement?
Go to Step 4
  1. [*]
Does the DTC reset?
Go to Step 2
System OK
Old Dec 21, 2011 | 11:56 PM
  #17
gmtechs's Avatar
basically its telling u the module is no good
need to replace it
Larry Ulmenstine
Mar 20, 2015 08:53 AM
JGoodmon
May 18, 2014 10:38 AM
SuperC
Apr 16, 2011 07:46 AM
ro9beam2002
Mar 21, 2007 10:00 PM
backbumper1984
Jun 1, 2005 04:42 PM
