2000 Deville base model no start
Old Dec 19, 2011 | 07:42 AM
brianlofton's Avatar
Default 2000 Deville base model no start
The security light flashes when I try to start the car and there is no sound of a fuel pump and the starter doesn't even try to kick. I have disconnected the battery for fifteen minuites and tried again. I have also tried many combinations of unlocking and locking the doors to include activating the panic button on the key fob. It was fine when I parked it and now de-nada... please help I have work in a few hours...
Old Dec 19, 2011 | 09:13 AM
it threw a bunch of codes faster than i could write them... pcm p0171 1860 0174 0335 0336 0340 0341... irc v1301 ipm b1004 ipc b1004
Old Dec 19, 2011 | 09:48 AM
gmtechs's Avatar
right now the problem u r having is the security light, first make sure battery is fully charged and the connection are good
Old Dec 19, 2011 | 09:50 AM
gmtechs's Avatar
after u do this try to start the car , turn to crank and let key go back to the position as if the car started leave it there for 10- 15 minutes the security light should stop flashing turn off vehicle and then try restarting it
Old Dec 19, 2011 | 10:45 AM
Ty i will do this now
Old Dec 19, 2011 | 12:07 PM
Default ok...
Battery was wrong size all together got a new battery and installed... no security light inappropriately but no start... have just started without starting the car and left KO for the 10-15 min you mentioned
Old Dec 19, 2011 | 12:35 PM
it didn't work
Old Dec 20, 2011 | 07:30 PM
gmtechs's Avatar
clean all codes
so no security light
when u put key in does it go on then off
Old Dec 20, 2011 | 07:36 PM
gmtechs's Avatar
if the code b1004 does not leave then module is no good
Old Dec 20, 2011 | 08:29 PM
Default phew
Ok today I went and got a new key cut... after the three key on key off cycles to program the car to the key, the dash display said "starter disabled" ???
