2000 cadillac eldorado 4.6 northstar p0386
Old Mar 22, 2012 | 05:32 PM
agentsmith1's Avatar
Default 2000 cadillac eldorado 4.6 northstar p0386
I have recently pulled the motor and overhauled it because of the heads leaking. I have currently got everything running was getting a p0385 code which I have tracked down to a broken wire, however I did replace both crankshaft sensors. Now I am receiving a p0386 code. does this mean I need to do a relearn procedure on the car, yes i did take the crankshaft out and inspected the bearings. 4.6 northstar engine
Old Mar 22, 2012 | 09:33 PM
gmtechs's Avatar
did u put the sensors in the right spot
Old Mar 23, 2012 | 10:44 PM
yes, upper is b yellow/black is signal, yellow ground and light green is hot,
a is lower with yellow/black as ground, light green hot, blue/white is signal. according to manual
itisian
Nov 28, 2013 10:50 AM
nccadikingz
Apr 22, 2013 06:54 PM
bobbyking1988
Mar 23, 2013 04:19 PM
agentsmith1
Mar 22, 2012 05:21 PM
caddydaddyuk
Aluminum Block V8s
15
Jul 30, 2009 09:03 AM
