2000 Cadillac Deville Speedo Problems!
Old Jun 15, 2010 | 03:05 AM
64caddyuk's Avatar
Unhappy 2000 Cadillac Deville Speedo Problems!
I have a 2000 cadillac deville dhs and I am having problems with the speeedometer - it does not move at all - just sticks at 0. I have hooked a obd2 tool into it and drove it around and the speed shows fine on this...So next I tried disconnecting the VSS sensor wire from the sensor on the output shaft - then drove it with the obd2 tool and it now does not show the speed on it - so I guess it cant be anything wrong with this sensor...I also pull no DTC codes and the check engine light is not on and have driven 20-30 miles and still no light - but no speedo either! Please can anyone point me in the right direction? If the input speed sensor inside the trans was knackered - would'nt this normally log a fault? I have checked the wiring and all seems okay. Please can anyone help - im so frustrated nothing ever seems to go right with this car!
THANKS!
Old Mar 22, 2015 | 01:37 AM
mark77090's Avatar
Default input shaft speed sensor
there are 2 of them , if the speedometer doesn't work it's the one inside of transmission not the one on the side of trans
brushwolf
Dec 1, 2012 07:22 PM
BB2nite
Sep 18, 2011 07:09 PM
BB2nite
Aug 13, 2011 04:35 PM
Conrad
Sep 21, 2007 10:15 PM
threnc
Jun 30, 2006 08:24 PM
