1995 sedandeville 4.9 wont start
Old Jun 13, 2010 | 08:54 PM
will612's Avatar
Unhappy 1995 sedandeville 4.9 wont start
I have a 95 deville 4.9 L had car running cut it off and tried to restart and it did nothing still had power but no crank found blown ignition fuse replaced it and had to jump car to get it started now my info display dont work just the dash warning lights come on thats it and than it will run not even a minute than just dies out i dont think its the alternator especially with what just happened with the igniton fuse hoping may be it could be a blowed relay I checked all fuses and they where good and if its a relay that would cause that where is it if anty body can help please do cause im at a lost right now thanx for reading (listening!) to my troubles...
Old Jun 14, 2010 | 02:35 AM
will612's Avatar
Exclamation also
also when I replaced the ignition fuse I dont understand why the battery would be drained if never tried to crank???also do this car have a relay or fuse that control the display or disrupt the power supply note I checked all fuses in trunk and fuses under hood are there any other places I should be looking
Old Jun 14, 2010 | 05:46 AM
jhon herry's Avatar
There's going to be 2 hoses running from the pump down to the gear box (rack-pinion). That you will need to un screw in order to remove the hoses.It not hard to do ,just a loittle oily.
Old Jun 14, 2010 | 01:47 PM
will612's Avatar
Thumbs up responf
Is that where I would finfd the relay box on the car and would it be labeled and thank you very much
Jack West
Nov 12, 2012 11:07 AM
sparky570
Aug 6, 2012 08:55 PM
WARREN4466
Aug 8, 2008 07:15 PM
umoms
Mar 3, 2008 02:04 PM
demo bob
Aug 9, 2006 11:34 PM
