1992 caddy saden deville
Old Aug 1, 2007 | 09:37 AM
CaddyGeorge1's Avatar
Default 1992 caddy saden deville
Just need some input, had frount passenger side spindle and barrons replaced also replace brake. no it making a scuffing noise when you drive it seems to stop when you slow down...any input will be helpful
thanks,also how do you inable the sencer light for brake and check engine..
Old Aug 1, 2007 | 11:53 AM
76eldoragtop's Avatar
Default RE: 1992 caddy saden deville
ORIGINAL: CaddyGeorge1
Why woudl yuo wnat to inabal the sencer lihgt??
Old Aug 1, 2007 | 12:08 PM
barrons ?
what is it?
Old Aug 2, 2007 | 11:12 AM
brougham1's Avatar
Hey Gearge: You most likely have a caliper problem. If your calipers don't retract slightly after braking then you will get the scuffing sound. Not to mention pre-mature brake wear. The calipers are not that much money and are easy to change, just be sure to bleed your brake lines well after the change.Good luck and stay out of truble.
DonL
Mar 3, 2008 12:14 PM
111romans
Jan 24, 2008 05:07 PM
Bosshound
Sep 18, 2007 06:35 AM
Claudeezy80
Sep 2, 2007 09:37 PM
Eddiek
Aug 8, 2007 02:11 PM
