1992 DeVille w/50,000mi, No Heat...
Old Mar 3, 2008 | 12:14 PM
DonL's Avatar
Default 1992 DeVille w/50,000mi, No Heat...
I recently blew a heater core. It was a waterfall, much more than just a "leak'.
The core changeout was easy yesterday but still no heat. The damper is working fine, checked it right away, the "T" under the hood at the firewall is also OK. I did notice the coolant is hot going into the core but the outlet hose is cold. I'll guess the outlet hose is clogged, possibly where it returns to the block?? Maybe this caused an increase in pressure that finished the old core off??
Yesterday was summer-like, today it's rainy and cold so crawling under the car is not much of an option, so my question is "where does the outlet hose return to the engine? I'm guessing it could be clogged at that point since the hose obviously must slip over a nipple somewhere, which could be a logical spot to check first I suppose. It's hard to follow looking from under the hood.
The car has a little over 50,000 miles on it and is in pristine condition, but it's been driven little in the past 5 years.
Any other ideas?? Thanks....
luckydaughter
Feb 3, 2013 06:11 PM
INTENSE_FLEETWOOD
Automatic Transmissions
Sep 12, 2007 08:27 AM
Angelo
Vintage & Classic Cadillacs
Nov 29, 2006 07:08 PM
Ron631
Jul 5, 2006 04:37 AM
eldo
Feb 27, 2006 08:20 PM
