1990 Seville ABS Light / ECBM
Old Apr 13, 2015 | 09:19 PM
Keys85's Avatar
Default 1990 Seville ABS Light / ECBM
I am getting the ABS light (steady on) 80% of the time. Jumping pins A and H on ALDL reveal no codes. According to the shop manual, ABS steady on, with no codes, indicate a hard fault. My manual is for a 1991. My car is a 90. The schematics do not appear to be the same. Similar but not the same. According to the 1991, a steady ABS light with no flash codes indicates the ECBM grounding pin 29 through crtk 852 because relay is not being energized for hydraulic modulator. I have a Teves Mk II system in my basement. (I replaced the entire master cylinder last summer because of a bad ac***ulator). There are no relays in this system I have in the 90. The shop manual shows relays under the hydraulic modulator plate on the MC, I opened up the one I have in the basement, and no relays - just solenoids.
I checked all fuses. Cleaned all terminal contacts. And have ordered the 1990 shop service manual. Any information on this problem greatly appreciated.
Old Oct 2, 2015 | 01:24 PM
Fatties's Avatar
Banned
I guess because its an old model but has to maintained i am sure and also for me knowing a lot of things keeps it all useful for us on all the outcome that it carries i am sure it can all be taken care of wisely.
RGalvez
Oct 25, 2013 01:11 PM
madmax123
Sep 2, 2013 02:08 PM
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
jono6406
Feb 13, 2008 12:13 PM
