1987 Seville fuel problem - advice?
Old Mar 4, 2014 | 01:16 PM
whippet's Avatar
Default 1987 Seville fuel problem - advice?
My dad's 87 seville with 66k miles conked out just leaving a parking area on a return trip of 10miles. Towed home. Engine cranks well, has spark, won't start and service now light is on. I sprinkled some gas underneath air filter and car immediately started and continued to run well. After 5 minutes I turned off and it restarted easily. Same after an hour. However, later in the day and also days later won't start unless it's primed as before. Codes on dash are E20 and E52. Thoughts on how to proceed are appreciated.
Old Mar 4, 2014 | 07:40 PM
I would check fuel pump relay
Old Mar 4, 2014 | 07:45 PM
SimpsonTruckDriver's Avatar
Also check the Idle Speed Control. It may be dirty or broken, and keeping the throttle body plate wide open.
TS
Old Mar 12, 2014 | 12:54 AM
whippet's Avatar
Thanks guys. It was the fuel pump relay.... a relief
jpb
Cadillac Allante 1987 to 1992 Phase I & II
May 25, 2012 10:39 AM
HighRise
Jul 11, 2011 05:25 AM
thermox
Dec 29, 2008 11:31 AM
greencreampuffSTS
Jul 30, 2007 09:28 PM
bishopxm
Mar 5, 2006 09:32 PM
