New Map sensor didn't fix the problem
Old Nov 20, 2008 | 07:08 PM
planocolt's Avatar
Default New Map sensor didn't fix the problem
Hello all! I have a 1999 Cadillac Seville STS. 101,000 miles.
About a week ago the car started stalling. Well stalling and surging.
I took it to Autozone and the car was popping P0101 (Map Sensor).
I replaced the sensor and I still have the same problem.
Any ideas?[>:]
Old Nov 21, 2008 | 11:45 AM
carnut's Avatar
Default RE: New Map sensor didn't fix the problem
So check the hose to it. codes only point to the area to diagnose, rarely to replacing a component. If voltage doesn't get to it, if the hose is kinked or full of moisture then that code will set and the MAP itself is OK. Having a code and no service manual only leads to parts replacement which gets expensive.
Old Nov 21, 2008 | 04:31 PM
planocolt's Avatar
Geeze P0101 is the MAF sensor not the MAP..... should have checked the info on the Autozone scanner myself......
Old Nov 25, 2008 | 10:57 AM
planocolt's Avatar
And on and on. I replaced the MAF sensor. Cleared the codes via the climate control and within 5-10 seconds it pops the code again (P0101).
I am going to borrow a friends OBD2 scan tool, does anyone know what "normal" readings are from the MAF at idle?
Cord
Jun 24, 2012 09:17 PM
Packard8
Vintage & Classic Cadillacs
Jul 18, 2011 08:14 PM
dwilliam1963
May 24, 2007 08:45 PM
mercedes84black
May 19, 2007 02:45 AM
misfit6794
Jan 7, 2007 07:23 PM
