89 Deville Loosing Coolant
Old Jan 27, 2025 | 05:46 PM
89DevilleMAG's Avatar
Default 89 Deville Loosing Coolant
Hello All!
I have an 89 Deville 4.5L. The past month or so I keep having to add coolant to the radiator, but my overflow reservoir is always full. It seems as the coolant is not being drawn back into the radiator after the engine cools down. I replaced the radiator cap, flushed the heater core and radiator as of recently as well, but problem still occurs. I always added the cooling system sealer tabs to radiator as per instructions after coolant changes, but after the last time, my heater core was plugging up. So, I refrained from using those tablets the last time. Now after last flush of the heater core, I have noticed the issue of the coolant loss after every few hundred miles. I did check the oil and havent noticed any coolant there. Any tips or info on this issue would be appreciated!
Thanks,
Mike
RilSpecific
Jun 21, 2013 04:57 PM
dukejet62
Jul 19, 2012 01:21 PM
Aluminum Block V8s
Nov 11, 2009 11:27 AM
akolodny
Feb 24, 2008 07:23 AM
92_Daddylac
Mar 18, 2007 02:19 AM
