ht4100 hot start
Old May 11, 2014 | 09:29 AM
tmd171's Avatar
Default ht4100 hot start
my problem is hard starting my '85 eldo when hot. The problem occurs when the car has been driven then stopped for a short period, it's difficult to restart. The problem appears to be fuel vaporizing, or vapor lock. Fuel pressure holds steady at 10 psi while cranking but little/no fuel from injectors. Bleeding off fuel from the pressure line comes out foamy a couple ounces then clears and car will start and run fine. Filter has been replaced, pump is assumed ok as pressure is normal.Any ideas are appreciated.
stealtreasure
Mar 10, 2016 02:37 PM
Mags1
Nov 19, 2010 07:37 PM
pkared
Aluminum Block V8s
May 8, 2007 01:38 AM
jims 85 Deville
Nov 5, 2006 02:05 AM
