ht4100 hot start
my problem is hard starting my '85 eldo when hot. The problem occurs when the car has been driven then stopped for a short period, it's difficult to restart. The problem appears to be fuel vaporizing, or vapor lock. Fuel pressure holds steady at 10 psi while cranking but little/no fuel from injectors. Bleeding off fuel from the pressure line comes out foamy a couple ounces then clears and car will start and run fine. Filter has been replaced, pump is assumed ok as pressure is normal.Any ideas are appreciated.
