HT4100 motor
Old Oct 29, 2006 | 04:25 PM
jims 85 Deville's Avatar
Default HT4100 motor
I started having a noise problem with my 85 Deville 4100 motor. I hear a grinding noise when starting the car and also when I accelerate and when turning the motor off again grinding with a bell sound. During the run time it runs smooth. I've taken off the serpentine belt and get the same sounds, so that tells me the problem is internal.
Hopefully some of the members here can tell me whats going on with my motor, is it time to replace this 88K motor?
Any help will be greatly appreciated.
Thanks, Jim
Old Oct 30, 2006 | 10:48 PM
Silverfox's Avatar
Default RE: HT4100 motor
Take it into a GM repair shop for a FREE diagnostic estimate of repairs...that will get the noise problem diagnosed then either do the work yourself or if you know of someone.....
Old Oct 31, 2006 | 03:57 AM
brougham1's Avatar
Hi Jims: Just to check something before you get into spending money, see if your starter is fully retracting on the bendix after a start. you should see the gears quite close together when doing an inspection if this is the problem. Good luck.
Old Nov 5, 2006 | 02:05 AM
Hi brougham 1
Took your advice and replaced the starter but unfortunatly that didn't resolve the problem. The noise sounds like it comes from the front of the motor, timing chain, cam area ect. Do these motors have problems there?
Anyway I wish to thank you for your help.
Jim
PS In case I need a new motor can anyone suggest a good source.
stealtreasure
Mar 10, 2016 02:37 PM
Oct 15, 2008 07:49 PM
devilleish
Oct 13, 2007 10:43 AM
Kdaddy
Aluminum Block V8s
Aug 9, 2007 12:31 PM
pkared
Aluminum Block V8s
May 8, 2007 01:38 AM
