traction control
Old Nov 18, 2006 | 02:57 PM
otel800's Avatar
Default traction control
my abs indicator is on and my display reads TRACTION CONTROL DISABLED... how can i correct this problem?
Old Nov 29, 2006 | 09:07 PM
Krashed989's Avatar
Default RE: traction control
What year is your car? If it's OBD-I (1990-95) then you can press the OFF and warmer (red) buttons simultaneously for about 5 seconds untill the LED's light up. It will then enter diagnostics mode and show you the codes. If it's OBD-II (1996-01) you can do the same thing by pressing the OFF and passenger warmer buttons simultaneouly on the climate control panel.
The codes will reveal what the problem is.
Old Feb 7, 2007 | 01:12 PM
TRosell14843's Avatar
I am have a 2001 sts what OFF button areyou referring to? I understand the pass. warmer button on the climate control.
Old Feb 16, 2007 | 02:07 AM
Katzmans Caddy's Avatar
OFF is climate control off. Appears to me like you have a bad ABS sensor on one of your drivewheels. This would explain the ABS light and TRACTION DISABLED. Traction control works through the ABS system by automatically applying brake to the spinning drive wheel that has broken traction. If one sensor is gone the ABS can't perform and since Traction Control is run off ABS the computer disables it.
00dts46
May 23, 2017 09:50 AM
Adrian_407
Jun 21, 2011 04:08 PM
Adrian_407
Jun 18, 2011 11:53 AM
STS1994
Jan 4, 2006 07:30 PM
xbenzman
Aug 18, 2005 05:47 PM
