Cadillac SRX The SRX offers the versatility of a mid-size sport utility vehicle with a sports car feel
New Brakes?
Old May 11, 2008 | 02:38 PM
DJsSRX's Avatar
Default New Brakes?
I've got a 2004 SRX V6 and I'm thinking about buying a new set of drilled/slotted brake rotors with ceramic pads from eBay and have my local brake shop put them on for me. I can get these from eBay for about $300.00 and the labor will be about $250.00. Has anyone else done something like this before? I've researched eBay and all ads say their rotors/pads are OEM and will fit the existing calipers with no problem.
Thanks
[IMG]local://upfiles/6319/376131B71276443881FE89F494364078.jpg[/IMG]
Old May 11, 2008 | 05:10 PM
Default RE: New Brakes?
ORIGINAL: DJsSRX
Thanks
unless you are into racing, or live in Europe and drive the Autovan, i recommend against ceramic pads ..
they will perform poorly on average street driving. They dont do so well until they get hot.
do check these out in our website
The BEST car Cadillac ever made is the ..
https://www.cadillacforum.com/m_9438/tm.htm
MY Cadillac has more miles than yours thread ..
https://www.cadillacforum.com/m_12353/tm.htm
Average age of our Cadillac owners
https://www.cadillacforum.com/m_931/tm.htm
Why you should change to coolant the day you buy the Cadillac
https://www.cadillacforum.com/m_7193/tm.htm
https://www.cadillacforum.com/m_7388/tm.htm
CODES .. We need CODES to help you.
https://www.cadillacforum.com/m_18197/tm.htm
https://www.cadillacforum.com/m_17425/tm.htm
https://www.cadillacforum.com/m_11904/tm.htm
How do you get help from our TECHs ?
Cadillac FAQ MENU
https://www.cadillacforum.com/m_6733/tm.htm
Cadillac Technical FAQ section
https://www.cadillacforum.com/forumid_64/tt.htm
Cadillac Allante FAQ
https://www.cadillacforum.com/forumid_83/tt.htm
The Cadillac Allante Pub - Allante not needed.
https://www.cadillacforum.com/m_21055/tm.htm
Allantesource.com Allante PROCEDURES MENU
https://www.cadillacforum.com/m_18287/tm.htm
https://www.cadillacforum.com/forumid_60/tt.htm
Cadillac History
https://www.cadillacforum.com/m_6356/tm.htm
Welcome to CadillacForuM.com
Old May 11, 2008 | 05:19 PM
DJsSRX's Avatar
Thanks for the info!!!
Old May 13, 2008 | 07:25 PM
Caddy Wagon's Avatar
Hey DJ,
I just bought new rotors/pads off of Ebay. There were 3-4 different sellers with a similar packages, and as Stomper suggested, I steered away from the ceramic pads. The drilled/slotted rotors aren't really necessary either, but they just look cool.
I should receive them this week, and am planning on doing the install next. I can provide some details when I get them in, if you would like. I'm hoping the claims of OEM size and fitment are true.
I'm having a friend help with the install, since I haven't done brakes before. He is a race driving instructor so he's used to do doing lots of brake replacement.
Old May 13, 2008 | 07:33 PM
DJsSRX's Avatar
Yes please keep me informed.
Thanks!!!
Old May 13, 2008 | 08:00 PM
Will do. The OEM rotors are pretty ugly after they get all rusty. We have the 18" wheels, and the spokes are fairly slim, so these show really bad.
The new ones are supposed to be stainless and zinc coated, so helpfully they will stay pretty.
I had a wheel off today changing a turn signal bulb(another thread) and decided to clean up the caliper. I was thinking about painting the calipers silver when I do the rotor change, but after some cleaning, it looks pretty good. I'm not going for the tuner look, but nice stainless rotors look great with a clean caliper. I used some degreaser and a steel wire brush, and now they look like new.
Old May 14, 2008 | 01:29 AM
ORIGINAL: Caddy Wagon
painted rotors can do wonders for many cars.
take a look at the Ferrari cars.
Old Mar 3, 2011 | 09:49 PM
niteryder's Avatar
Default Replace Rotors - 2005 SRX
Am looking for recent posts on replacing brake rotors. Is there a "set screw" or something similar, that must be removed to remove the existing rotors? I am unable to get them off. I've removed the caliper mounting bracket, etc. but the rotors will not budge.
Old Sep 17, 2017 | 11:28 AM
Chris M. Dickman's Avatar
Replacing brake pads in 2004 srx is about the easiest thing possible, anyone can do on your own and doesn't take but no more than 5 mins per tire/brake......I also then removed Calipers and painted and it made a huge difference, looked a million times better. Hardest and longest part was just cleaning 13 years of gunk from the caliper and the caliper bracket. took probably 6 hours or so per caliper....ended up using power drill with some serious wire bits and my dremel and that finally did the trick. Only real advice i could give would be to not paint until you do get them 100% clean because I was fed up of cleaning and just tried painting while stir dirty and just flat out didn't work. Also, make sure to get actual caliper paint from auto parts store or at the very min at least high heat paint. Lastly make sure to prime first, then paint, then clear coat. It makes a world of difference doing it right compared to just getting it done.
Old Oct 1, 2017 | 06:34 PM
rqstudio's Avatar
Drilled Disk, Ceramic Pads, Fake Brembo calaper covers, Vogue wheels --- THE BOMB! Ceramic pads were quiet and didn't chew up the rotors, however the rotors did show surface rust in a short while. I'd get as much paint on and inside the surfaces of the rotors as possible beforehand. (I did mine silver but black may look better)
99STSGUY
Jun 5, 2009 12:03 PM
summermichelle1
Mar 4, 2008 10:17 AM
ruaskier2
Oct 5, 2006 02:59 AM
tuttibear
Jul 29, 2006 01:04 PM
donny54
Jun 22, 2006 09:54 PM
