stuck scratching my head with this trans...HELP!!!
I have a 92 seville sls that i bought about a year ago. When i bought it i noticedI had a hard time shifting the shifter into reverse only. A while after driving with only this problem thecadillac no longer went into reverse unless it was in neutral rolling backwards and while rolling I clicked it into reverse. Doing this it would engage and it would work fine. Now it has been sitting for a few months and I charged the dead battery so i could start it pull it in the garage and work on it but it will not move in any gear! Not even in neutral. I can feel and see the motor torque when shifting but it does not move. I tried rocking it to no eval. I also put in neutral and jacked up both front tires and was able to spin them freely, then jacked up the back and was able to spin those tires also. But the darn thing just wont budge. I cant even push it in the garage to work on it...PLEASE SOMEONE HELP!!!
There is a tranny guy on another board that Stealth might be familiar with. I will see if we can get him over here, or at least an answer to your question, if no one else responds.
VIN9
Aluminum Block V8s
Sep 19, 2007 09:18 PM
