Power steering hose
Old Jan 15, 2008 | 07:48 PM
TWIZLR's Avatar
Default Power steering hose
Just curious, I have a power steering hose leak from the pump to the rack. The hose is cheap, $48.00. My question, it seems straight forward, take out the old and install the new, but do I have to bleed the line? If so, how? Thanks in advance for any help.
Old Jan 15, 2008 | 08:33 PM
brougham1's Avatar
Default RE: Power steering hose
All you should have to do is turn the steering to the extreme right and then to the left a few times to chase the air out of the system.
Old Jan 16, 2008 | 06:04 PM
TWIZLR's Avatar
Sounds easy enough, thanks
Old Aug 5, 2008 | 08:06 PM
quasi's Avatar
Hello,
I have the same situation as you did back in January. My high pressure power steering line is leaking. Were you able to replace yours? Just wanted to check on howdifficult it was to disconnect at the steering gear. Thanks.
Mark
ejscarfo
Jan 6, 2009 08:50 AM
May 6, 2008 11:37 PM
etaylor
Jan 20, 2008 11:13 PM
cortewardy
Dec 12, 2007 06:11 PM
eechapa
Nov 2, 2007 09:07 PM
