Left Turn Signal Don't Blink
Old Mar 30, 2009 | 12:46 AM
GMAN's Avatar
Default Left Turn Signal Don't Blink
My 96 Seville STS turn signal doesen't blink on the drivers side. This is a bit strange to me. They blink rapidly. However, while the car is in gear, and I select the left signal, it just lights up solid and will not blink. When it is in Park, it blinks, all be it rapidly though. What's going on here?
Old Mar 30, 2009 | 09:24 AM
gman... what happens when you put the 4-way flashers on??? it sounds as though you have a couple turn signal lights out, or possible the flasher unit is bad.... nothing big.... let us know
Old Mar 30, 2009 | 11:40 AM
GMAN's Avatar
Rickyd, I replaced all the bulbs, check the fuse, and I peeked uneder the steering column. Is there something else I should be looking for?
Old Mar 30, 2009 | 03:30 PM
did this just all the sudden start not working properly? now it sounds as though you got some wrong bulbs in the wrong sockets, or have you checked or replaced the flasher unit? what happens when you put on the four ways? has the car been wrecked?
Old Mar 30, 2009 | 05:36 PM
GMAN's Avatar
I've only had the car for a couple of months. Only recently that I started to drive it. The car hasn't been wrecked, it is immaculate. The bulbs in the back are 2057 bulbs. When I have the hazards on, all of the lights flash. One thing I've noticed is the drivers side rear light is dimmer that of the passenger side rear. I replace the flasher unit that the Chilton book refers to. Is this what was supposed to be replaced?
Old Mar 30, 2009 | 07:05 PM
With lights on and 4 ways on are both sides blinking the same? Flasher you changed paers to be hazard. car uses turn signal module - fancy flasher - 3 wires
Old Mar 30, 2009 | 07:44 PM
GMAN's Avatar
I'm not quite sure i understand your question. All sides blink. Drivers side just don't blink while the car is in Drive, and the driver's side rear is dimmer than normal. If the picture is not for the signal, what does it look like?
Old Mar 30, 2009 | 09:08 PM
Have you tried it with the lights on? When light are off sometimes bulbs with poor grounds will back feed on lighting circuits to ground. With lights on, lighting circuits are powered up, not allowing it, so a lamp with ground fault wont blink, not correctly - alternates - with adjacent lamp, or dimmer than the same lamp on opposite side of car.
Old Mar 31, 2009 | 10:18 PM
GMAN's Avatar
Ok, here is what i found out. I had a burnt out fog lamp on the passenger light. I had previously noticed that the driver side blinker would not blink when the fog lights were on. They still blink fast though. I know I am getting closer to solving this problem. Any ideas would greatly be appreciated.
Old Apr 1, 2009 | 06:12 PM
From earlier post, Check ground on left lamp that is dimmer than the others. It not unusual for the sockets to fail.
