Left Turn Signal Don't Blink
My 96 Seville STS turn signal doesen't blink on the drivers side. This is a bit strange to me. They blink rapidly. However, while the car is in gear, and I select the left signal, it just lights up solid and will not blink. When it is in Park, it blinks, all be it rapidly though. What's going on here? :confused:
gman... what happens when you put the 4-way flashers on??? it sounds as though you have a couple turn signal lights out, or possible the flasher unit is bad.... nothing big.... let us know
rickyd |
Rickyd, I replaced all the bulbs, check the fuse, and I peeked uneder the steering column. Is there something else I should be looking for?
did this just all the sudden start not working properly? now it sounds as though you got some wrong bulbs in the wrong sockets, or have you checked or replaced the flasher unit? what happens when you put on the four ways? has the car been wrecked?
rickyd |
Originally Posted by rickyd
(Post 30514)
rickyd http://www.springwebdesign.net/Seville/100_2107.jpg http://www.springwebdesign.net/Seville/100_2108.jpg |
With lights on and 4 ways on are both sides blinking the same? Flasher you changed paers to be hazard. car uses turn signal module - fancy flasher - 3 wires
Originally Posted by slowroll
(Post 30527)
Have you tried it with the lights on? When light are off sometimes bulbs with poor grounds will back feed on lighting circuits to ground. With lights on, lighting circuits are powered up, not allowing it, so a lamp with ground fault wont blink, not correctly - alternates - with adjacent lamp, or dimmer than the same lamp on opposite side of car.
Ok, here is what i found out. I had a burnt out fog lamp on the passenger light. I had previously noticed that the driver side blinker would not blink when the fog lights were on. They still blink fast though. I know I am getting closer to solving this problem. Any ideas would greatly be appreciated.
From earlier post, Check ground on left lamp that is dimmer than the others. It not unusual for the sockets to fail.
