Help! Changed rear brake pads now car won't start
Old Jul 8, 2011 | 07:25 AM
scooter101's Avatar
Default Help! Changed rear brake pads now car won't start
I am hoping I can get some help. I have a 2003 Seville SLS. I recently removed the passenger side rear wheel to check the brakes. I removed the two bolts that hold the caliper and removed the disk. The pads were good, but I cleaned off some of the rust from the rotors and put everything back together. I did not hit the ABS wire that connects to the wheel assembly. However I had to move the wire around a little while I loosened and tightened the bolts.
After putting the wheel back on I tried to start the car. NOTHING! I get some dash lights but no click or anything. I am suspecting something in the ABS system is causing the problem. I removed the wheel and checked the ABS wire connection and it appears OK. But still I get nothing when I try to start the car.
Very frustrating... thanks for any help.
Old Jul 8, 2011 | 03:32 PM
Katzmans Caddy's Avatar
Default Give it a boost
I think your battey is dead.
Old Aug 2, 2011 | 02:26 PM
Chuwee's Avatar
Yes, brakes has nothing to do with the starting system.
Old Aug 14, 2011 | 02:55 PM
justtalkin's Avatar
Yes, somewhere in the process, you ran your battery down. Maybe left an accessory light on, doors open, hood ,and trunk open, etc...would all drain the battery. If your battery is really old, you might pry off the top caps and make sure it has adequate levels of water in all 6 the cells. Just because batteries are called maintenance free, doesn't mean they really are.
GreggB
Aug 10, 2014 10:29 AM
ctshell
Feb 5, 2012 02:18 AM
Jan 28, 2009 04:12 PM
99STSGUY
Jan 21, 2009 08:29 AM
motor44
Apr 13, 2007 10:24 PM
