FUEL FILLER PIPE
i have 96 sts and my fuel filler pipe is rotted i need a new one ...i was wondering where i could maybe get one cheap the dealers price is outrageous ...and what other cadillacs will fit mine ......and is it possible to make one out of rubber fittings
if you want to go the cheap route, yes you can make one out of rubber fittings, just make sure you get the type for fuel. That would be the cheapest and faster way to fix, besides there is plenty of car that have rubber fuel lines so it should not be too much of a problem if you do that.
The sending unit goes in from the top of the tank and the fittings are on that with a gasket usually. The tank seam is in the middle more or less of the tank. Overfill leaking points to one of those imo.
dreyerot
Dec 2, 2013 01:01 AM
rideslikeacaddy
Oct 8, 2011 12:56 PM
