Changing Tail Light SLS
it is real easy. on each side remove the plastic cover just on other side of tail lamp( on inside of truck). the there are 3 ***** to turn to remove tail lamp can loosen with hands usually. once remove **** the tail lamp falls forward and can twist off the bulb that is out.
good luck
good luck
Sneekie, Thanks for your reply, The lights that need changing are the ones in the trunk lid and I finally figured I had to take out all the screws holding the whole back lens in and obtained access. Thanks for your reply anyway. Have a good one.
GTO_Greg
Mar 30, 2008 08:19 PM
brake, brakelight, bulb, cadillac, change, changing, custom, lamp, light, lights, replacement, replacing, sls, slscadillac, tail
