Changing Tail Light SLS
I looked on the inside of the trunk lid to access tail lights and no light bulbs are there. Can anyone assist on how to replace burned out tail light bulbs?
RE: Changing Tail Light SLS
it is real easy. on each side remove the plastic cover just on other side of tail lamp( on inside of truck). the there are 3 knobs to turn to remove tail lamp can loosen with hands usually. once remove nobs the tail lamp falls forward and can twist off the bulb that is out.
good luck |
Sneekie, Thanks for your reply, The lights that need changing are the ones in the trunk lid and I finally figured I had to take out all the screws holding the whole back lens in and obtained access. Thanks for your reply anyway. Have a good one.
