backfire and sputter
Old Jun 28, 2008 | 07:51 AM
cornfed's Avatar
Default backfire and sputter
hello all and thanks for any help in advance.
Heres my problem, I bought a 1997 seville with 130k miles in good shape, took it home and it overheated, took it back to the dealer and he replaced the thermostat, radiator, and water pump.....
Picked it up and drove it home and once again it overheated, had the dealer come and get it for repair again....he took it in and had it for a week and said he resurfaced the head, changed the head gasket, timeseted it.
I picked it up again and it doesnt overheat anylonger, took it for a 200 mile drive to test it..
2 days later it started idleing rough when started and the rpm would jump from about 600 too 800.....then go away for awhile as it was driven, until i took a exit ramp and it backfired as i was climbing the ramp.
Slight misses from 60-70 mph and in idle.
I bought this car3 weeks ago and the dealer hasdone alot aleady, but I owe him 3k yet for the purchase of it and hes taking payments as he is a friend of mine.
what would cause the problems, as before all the work it did not sputter at all.
here are the codes i pulled:
pcm p0603
p1578
msm b 2120
b 1656
thanks in advance
Old Jun 30, 2008 | 08:59 AM
Katzmans Caddy's Avatar
Default RE: backfire and sputter
P0603 - Control Module Long Term Memory Reset
P1578 - BBV Sensor Circuit Low Vacuum
B2120 - Lumbar Up/Down Sensor Failed
B1656 - EEPROM Write Error
I think you have a bad coil pack or bad connection from coil pack to spark plugs, which could have happened when head was done and things were being put back together. Check coil terminals and wires for connectivity and make sure coil posts ar nice and clean. Plugs should "snap" on in heads.
bk2futr
Mar 24, 2015 06:07 AM
shredder1989
May 20, 2012 10:28 PM
hoops560
Oct 31, 2011 09:48 PM
Sep 25, 2009 01:16 AM
bobfeder
Aluminum Block V8s
Oct 7, 2007 01:46 AM
