Aftermarket Radio/Nav
Old Oct 28, 2007 | 10:00 PM
xplordakota's Avatar
Default Aftermarket Radio/Nav
I had a 2001 Aurora with the Theftlock radio and by changing from stock to aftermarket radio you lost the Info Center (DIC) funtionality. The electronics for it were built into the radio. Is this the case with the 98+ sevilles? Can i put in a new radio without loosing aything else?
Old Oct 28, 2007 | 10:47 PM
Default RE: Aftermarket Radio/Nav
Radio is part of data loop. Mostly likely not, I would check with radio manufacture not saleman for potential problems ahead of time. Also search net for info specific to radio chosen and car your working with. Good experience may not show up, but bad ones mostly likely will.One other thing save original radio and do not let installer cut up harness. Original radio may have to re-installed temperarily if unusal electrical concerns develope long after radio is changed.
sethb17
Jan 15, 2010 05:10 PM
bobcal2000
Dec 30, 2009 03:07 PM
vet guru
Aug 14, 2009 08:01 PM
vet guru
Mar 15, 2009 03:36 PM
lberman
Jul 6, 2007 11:06 AM
