2003 SLS Shakes when stoped
Old May 19, 2008 | 10:54 PM
FriscoSLS's Avatar
Default 2003 SLS Shakes when stoped
I really need your help my 2003 cadillac sls shakes while its not in motion itsa really getting anoying i want to say it needs a tune up but i want your advise the car has 48850 miles on it now what wopuld be the type of tune up that i need now i bought the car with 41000 mile and have not done tune ups other than your oil change i really want to have a good guess on whats goin on before i take it to the mechanic and he trys to stick me witha big bill your help is verry well appreciated
Old May 19, 2008 | 11:35 PM
Default RE: 2003 SLS Shakes when stoped
ORIGINAL: FriscoSLS
tune up? unlikely ...
pull the CODES
check these threads.
The BEST car Cadillac ever made is the .. you get to pick.
https://www.cadillacforum.com/m_9438/tm.htm
MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars.
https://www.cadillacforum.com/m_12353/tm.htm
CODES .. Pulling & understanding CODES .. we need CODES to help you.
https://www.cadillacforum.com/m_18197/tm.htm
https://www.cadillacforum.com/m_17425/tm.htm
https://www.cadillacforum.com/m_11904/tm.htm
Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture,
Corp 800 #’s, unique shipping services .. etc ... take a look.
https://www.cadillacforum.com/m_9880/tm.htm
Average age of our Cadillac owners .. where everyone says they are 23.
https://www.cadillacforum.com/m_931/tm.htm
Why you should change to coolant the day you buy the Cadillac.
https://www.cadillacforum.com/m_7193/tm.htm
https://www.cadillacforum.com/m_7388/tm.htm
Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains.
https://www.cadillacforum.com/m_6036/tm.htm
Cadillac GM e-ghosts electric problems, intermittent codes, etc.
https://www.cadillacforum.com/m_6068/tm.htm
Help from our TECHs ? You really want to read this.
Cadillac TECH FAQ MENU .. pull up all the FAQ topics
https://www.cadillacforum.com/m_6733/tm.htm
Cadillac Technical FAQ section .. everything Cadillac
https://www.cadillacforum.com/forumid_64/tt.htm
Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc.
https://www.cadillacforum.com/forumid_83/tt.htm
The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in.
https://www.cadillacforum.com/m_21055/tm.htm
Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle
https://www.cadillacforum.com/m_18287/tm.htm
Hobby Corner .. Hot wheels, trains, whatever ..
https://www.cadillacforum.com/forumid_60/tt.htm
Cadillac History .. The real McCoy, from day one.
https://www.cadillacforum.com/m_6356/tm.htm
Welcome to CadillacForuM.com
Old May 20, 2008 | 10:00 PM
yes codes will help diagnosis what is up with your sls.... does the car, shake or miss when it is in motion? if it were me, id make sure the plug wires were on good, from what you are saying.....
did this just all the sudden start happening?....... is anything wet?.... keep the Forum posted.
Old May 21, 2008 | 12:16 AM
FriscoSLS's Avatar
Well i checked for codes and no codes come up no service light nothing i recently had my crank sensors replace could that be it this started hapenning 4 days after i got them replaced now do you think it might be the timing belt or carbon build up on the fuel injectors i checked the cars cooolant its alittle low and the engine oil has no signs of water in the head gaskets its really weird it feels like it shakes from the front of the engine
Old May 21, 2008 | 08:49 AM
ORIGINAL: FriscoSLS
Well i checked for codes and no codes come up no service light nothing i recently had my crank sensors replace could that be it this started hapenning 4 days after i got them replaced now do you think it might be the timing belt or carbon build up on the fuel injectors i checked the cars coolant its a little low and the engine oil has no signs of water in the head gaskets its really weird it feels like it shakes from the front of the engine
First, make sure you are pulling codes and not simply waiting for the car to trow them at you .. did you go through the procedure?
Many cars do the idling shake due to a defective or mal-adjusted idle control and/or carbon build up in the throttle intake .. not the fuel injectors, bad primary wires.
instead of providing possibilities of what may be wrong, we can help out better if you provide details of when / how it happens .. read the "how to get help from a TECH "
BTW, dont give a mechanic any possibilities either, you will pay extra for him to try that also. Details, details is what saves $$$.
Old May 21, 2008 | 02:39 PM
Katzmans Caddy's Avatar
Plugs or coil packs will do that. No plug wires on an 03 boys.
Old May 21, 2008 | 10:31 PM
FriscoSLS's Avatar
i am going trought the procedure of pulling the codes ived noticed that the shaking gets worse when im runnig low on fuel then once i put gas it doesnt shake as much
Old May 21, 2008 | 10:52 PM
FriscoSLS's Avatar
No codes come up its extreamly weird well i have a guy comming to diagnose the problem ill keep it posted but suggestions are still welcomed
HOTCADI
Sep 17, 2010 11:44 AM
paolo
Jan 7, 2010 10:08 PM
kade7236
Jan 31, 2009 02:18 AM
FriscoSLS
May 9, 2008 09:48 PM
420Deville
Oct 3, 2007 10:11 AM
